Problem in Mobile Verison
I have created some custom pages but that pages not showing on mobile version ?
Website is
http://www.rasalaa.com
This is because you use the mobile theme plugin. The mobile theme requires you to create separate pages using the mobile editor. Please read this guide: https://forum.tagdiv.com/the-mobile-theme/
How can i show web version same elements on mobile?
in Current theme there no option to add elements in mobile editor like WEB
2nd thing:
Yoast panel is hide from pages how can i enable again?
please solve my these two problems
When i update the theme then Yoast panel hide from all pages before update it was there.
i reinstall again yoast plugin but same problem tell me how can enable again in pages???
If you want to have the same elements on mobile simply disable the mobile theme plugin.
You must have hidden the yoast pannel on your site. Please check the screen options or contact the plugin author if you cannot manage to get it to show up. Maybe you have a plugin conflict going on preventing yoast from displaying the content on pages.
what if I wanted to keep the mobile theme but default it to have the same contents as the web version? Is it possible?
Thank you
Unfortunately no, because the mobile theme plugin will not render the page builder short codes. Using the mobile theme will result in not being able to use the page builder on mobile pages.
