Problem in Newspaper Theme
I have just bought a newspaper theme and installed it on my website, but I’m unable to do any settings/changes to the website design. Anything I do change from the themes panel and save settings, the setting not getting applied to the website. Can anyone help me, please?
Maybe you have installed a Prebuilt Website Pro, and the changes from Theme Panel will not apply to the Pro Prebuilt Website.
You can edit the pages and templates from the front end using tagdiv Composer.
Also, on our channel https://www.youtube.com/channel/UCOT1RiNysIPCTPSnVZskwtQ, you can find more videos that can help you and documentation https://forum.tagdiv.com/newspaper-theme-documentation/ and you can ask us here on the forum if you have any questions
What should I do to change things from the theme panel? As Tagdiv Composer will only allow me to edit pages separately. Please guide me to reinstallation so I can use the theme panel to do changes in design, or is there any other way?
Unfortunately, you cannot have a page template assigned to all your pages. However, you can copy and paste the elements to have the same design on all of your pages. Or, you can save elements or sections so you can import them easily on the other page. If you need text on a page template, then you should use column text or text with title element. “Column text” and “text with title” elements have a button called “edit content” and if you click on that button, the WP Editor will open, and you can add some text/code/shortcode there. Close the WP Editor from X, save the changes from Composer and view the page to see the changes. You cannot add custom text to each page as you can with single post content. You need to create each page with its own text in Composer.
