Problem issues with newspaper lates version
Dear Support,
I have just updated the lastest version
the problem found is:
— When Logging as admin: the style showing up
— When logging out: the style has been gone
I have done:
1 – Update 3 required plugin: tag composer, tag library, tagDiv Standard Pack
Please show me how to fix the problems
Best Regards.
Usually this is a cache problem, please make sure that you clear all cache, also if you are using Cloudflare (CDN), make sure that is set as in our guide from here -> https://forum.tagdiv.com/cloudflare-cdn/
Let me know the results!
