Problem mobile theme
I have a problem with the Newspaper theme. I want to use the mobile version and not the Amp version and it displays the mobile version on the PC when I activate mobile.
Can you please help me to understand and solve the problem.
Thank you
Usually, this happens with cache plugins. If the cache plugin does not have mobile support then the mobile theme version can be delivered instead.
The solution would be to use the recommended WP Super Cache plugin instead and activate these settings (especially the mobile device support): https://forum.tagdiv.com/cache-plugin-install-and-configure/
Also, please let me know what plugin for the cache you use now.
