Hello !
Those are standard versions. You cannot edit the content of it. You can translate those titles by going into Theme Panel – Translations.
In order to have those options editable you will have to create a Cloud template footer and edit it to your taste using the tagDiv Composer.
Hello !
You can have those removed if you use a Cloud Template footer and design it as you wish. Find out more about it here: https://forum.tagdiv.com/footer-templates/
You guys really have to produce a better tutorial than the link above about how to edit the footer content (as described in this support question). The link to the tutorial showing how to create a footer template, honestly is not sufficient to do it properly.
I gave up and just used Style 5 of the default that came with this theme, and this is good enough for me.
I love this theme, but some of the how-to’s are lacking detail.
Hello !
We are sorry for the inconvenience ! You can follow us here since we have started providing more video tutorials: https://www.youtube.com/user/tagdiv
