the problem of refreshment in Chrome. Recent articles do not appear. It does not help the cash side. For articles have appeared it is necessary to delete cookies. How do I fix this?
This seems to be a caching issue please make sure that you clear all the cache and purge your files if you use CDN.
We only recommend using just page cache enabled(default settings): https://forum.tagdiv.com/how-to-make-the-site-faster/ so make sure you use the same for your cahce plugin.
Also you can check this by creating a new post, disable all the plugins except of Visual Composer, clear the cache and purge your files if you use CDN and see if you articles appears.
