Problem upon fresh installation – Tagdiv Composer
Hi!
Tagdiv composer breaks the whole site both in front end and admin panel. You can check the errors here https://museal.net.gr/
If i rename the plugin folder the site looks ok though. Can you help?
Regards,
Anna
Hello !
Please send us a screenshot of your System Status Tab and make sure that all the requirements are met as you can see here: https://forum.tagdiv.com/requirements-for-newspaper/ ; You will have to first start looking for a plugin conflict. please deactivate ALL plugins except tagDiv ones, also if you are using child theme or cache plugin, deactivate them, clear all cache and try again.
Also you can try and remove and re-install the tagDiv Composer plugin and please send us a link to your website in order to take a look.
Let us know the results.
Hello, Vlad
The issue is here :
/var/www/vhosts/museal.net.gr/httpdocs/wp-content/plugins/td-composer/css-analyze/css-analyze.php : line# 507
I’ve commented the section and there’s no error. No extra plugin installed.
I’ve also imnported default layout [only design] to check if it makes any difference, but no.
Full error code :
Fatal error: Uncaught ArgumentCountError: Too few arguments to function {closure}(),
4 passed in /var/www/vhosts/museal.net.gr/httpdocs/wp-includes/class-wp-hook.php on line 287 and
exactly 5 expected in /var/www/vhosts/museal.net.gr/httpdocs/wp-content/plugins/td-composer/css-analyze/css-analyze.php:507 Stack trace:
#0 /var/www/vhosts/museal.net.gr/httpdocs/wp-includes/class-wp-hook.php(287): {closure}(NULL, 10, ‘tdc_google_font…’, true)
#1 /var/www/vhosts/museal.net.gr/httpdocs/wp-includes/plugin.php(212): WP_Hook->apply_filters(NULL, Array)
#2 /var/www/vhosts/museal.net.gr/httpdocs/wp-includes/meta.php(676): apply_filters(‘get_post_metada…’, NULL, 10, ‘tdc_google_font…’, true)
#3 /var/www/vhosts/museal.net.gr/httpdocs/wp-content/plugins/td-composer/legacy/common/wp_booster/td_wp_booster_functions.php(572): metadata_exists(‘post’, 10, ‘tdc_google_font…’)
#4 /var/www/vhosts/museal.net.gr/httpdocs/wp-includes/class-wp-hook.php(287): td_load_css_fonts(”)
#5 /var/www/vhosts/museal.net.gr/httpdocs/wp-includes/class- in /var/www/vhosts/museal.net.gr/httpdocs/wp-content/plugins/td-composer/css-analyze/css-analyze.php on line 507
Hello !
We can take a look to see what the issue might be there. Please contact us via email at contact@tagdiv.com and provide the following:
– admin url and credentials
Our team will take a look !
