Problem Visual Composer
No licenses found
If you have just purchased your direct Visual Composer license please hold on a bit – it seems Envato API haven’t provided record on your purchase yet. Please try again in a while. Make sure you have verified your Envato account via confirmation e-mail sent by Envato. Without activated account Envato is not able to process your licensing information. After activation of account please re-login into our Support Portal.
I do not have the option of visual composer. Please newspaper 7 has included this plugin, now make the purchase
Fixed backend, follow the instructions in this forum, plugin updated. frontend does not appear. In the menu of work, lack visual composer.
I thought the problem was solved, but no, the continuous problem and the solution on the forum it is no longer
There is a new version of Visual Composer WPBakery. View details of version 4.12. The automatic update is not available for this plugin. To receive automatic updates license activation is required. Please visit settings to activate your Visual Composer. Got Visual Composer in theme?
that no solution for this issue and the slider 5 same thing happens, require license
The price include visual composer and slider rervolution
Activate Slider Revolution for Premium Benefits. You can Enter an existing licence key or Purchase a licence key.
Please one solution. thanks
Hello J-Michael,
Please keep in mind that Visual Composer come bundled with our theme and you will have to use only the version which comes with the theme and not other to achieve better results. Our latest version of the theme is Newspaper 7.1.1 and the right version for required plugins are -> Visual Composer 4.11.2 and Social Counter 4.1.
As you can see, all the plugins are in constant development. Each plugin will have to be checked with our theme for a good working and this process it may take a while. For example, the latest version of Visual Composer is 4.12 and the latest version of the plugin which has been tested with our theme is 4.11.2. In the future, after our developers will check this latest version of Visual Composer with the theme and they will find that the theme does not need to do some adjustments for, we will release an update with the latest version of Visual Composer (4.12). Until we will release the update with these latest versions you will have to ignore these messages.
So, please notice that if you want to have the latest version of the Visual Composer, you will need to have the additional license of this plugin and also, we cannot say for sure if this version of Visual Composer will work 100% with the theme because this version it is in testing.
For more information about Visual Composer, please check our documentation here -> https://forum.tagdiv.com/how-to-update-visual-composer-plugin/
Thank you for responding, I understand, my problem is, I do not have the frontend visual composer, is there any solution?
I’m trying to Elementor frontend, but I would like that of visual composer, is included in newspaper 7 otherwise unfortunately I have to buy visual composer, with the cost that this has.
Hello J-Michael,
So, I guess that here is talking about the Front End Editor option. Unfortunately, our theme does not work fine with Frontend editor and our developers have decided to exclude it from the theme. You can enable the Visual Composer frontend editor by removing this code from theme’s functions – http://screencast.com/t/1N4LB7WhP2jR but unfortunately, will not work properly if you have tag div blocks on the page. Also, please keep in mind that our theme does not have such an option for landing page and it is not supported, sorry!
If you refer to something else, please provide more details.
