problem when changing the typography
I’ve changed the font in the theme panel/theme fonts and it is not working. The font doesn’t change.
this error comes out:
Notice: Only variables should be assigned by reference in /usr/home/eltotdebadalona.com/web/wp-content/themes/Newspaper/includes/wp_booster/wp-admin/panel/views/ajax_boxes/td_panel_theme_fonts/td_get_font_section_by_section_id.php on line 59
If I understand correctly you make some change in theme fonts like this https://www.screencast.com/t/mKOi57IdW and instead of this: https://www.screencast.com/t/fmnJLjvlG
you get an error, if is so please make that you have the last version of them, and also please check the Requirements for Newspaper ->https://forum.tagdiv.com/requirements-for-newspaper/
Also is possible to be a plugin conflict, please deactivate all plugins and try again.
