problem when I installation the plugs, Ajax error, then blank all my web.
same as the subject.
Hello !
Usually this issue is related to a firewall or security module which blocks admin-ajax.php request. Please verify the console for error while saving the settings on the Theme Panel, usually it displays a 403 or 404 error, if you have these errors, you will have to contact your host and let them know that your admin-ajax.php is blocked either by firewall or the security settings.
If you don’t use a security plugin, please ask your host about this, maybe you have a security module which blocks this.
If you use a plugin like Wordfence please set it in learning mode.
Let me know the results!
there didn’t displays a 403 or 404 error, just refresh the website, and gets all blank, main website and admin page also.
When I changed the plug fold name ” td-cloud-library”, the website will display well.
Fatal error: Allowed memory size of 134217728 bytes exhausted (tried to allocate 92 bytes) in /home/usle/public_html/wp-content/plugins/td-composer/legacy/common/wp_booster/td_util.php on line 2047
Hello !
Make sure that you have accomplished all the system requirements as in our documentation here: https://forum.tagdiv.com/requirements-for-newspaper/
If there is still a problem, you can send us an email at contact@tagdiv.com and provide admin login, as well as cPanel. We will take a look. Include a link to this topic in the email.
fix the issue, but the website become super slow.
After that the site should be god!
If there is still a problem, please let us know!
it is not help, still too slow
i’m give up, your code are so sucks.
If you want we can take a look to this problem, you can send us an email at contact@tagdiv.com and provide admin login, as well as cPanel. We will take a look. Include a link to this topic in the email.
We can provide a refund if you are not satisfied with the theme, you can request it here
– https://themeforest.net/refund_requests/new
Thank you for your understanding and sorry for the inconvenience!
