problem when I open website in mobile "www.indianpolicy.in"
Fatal error: Uncaught Error: Class ‘td_style’ not found in /home/u603820335/domains/indianpolicy.in/public_html/wp-content/plugins/td-composer/td-multi-purpose/styles/tds_icon/tds_icon1.php:9 Stack trace: #0 /home/u603820335/domains/indianpolicy.in/public_html/wp-includes/template.php(770): require_once() #1 /home/u603820335/domains/indianpolicy.in/public_html/wp-content/plugins/td-composer/legacy/common/wp_booster/td_autoload_classes.php(42): load_template(‘/home/u60382033…’, true) #2 [internal function]: td_autoload_classes->loading_classes(‘tds_icon1’) #3 /home/u603820335/domains/indianpolicy.in/public_html/wp-content/plugins/td-composer/td-multi-purpose/shortcodes/tdm_block_icon.php(193): spl_autoload_call(‘tds_icon1’) #4 /home/u603820335/domains/indianpolicy.in/public_html/wp-content/plugins/td-composer/legacy/common/wp_booster/td_global_blocks.php(27): tdm_block_icon->render(Array, ”) #5 /home/u603820335/domains/indianpolicy.in/public_html/wp-includes/shortcodes.php(356): td_global_blocks::proxy_function(Array, ‘ in /home/u603820335/domains/indianpolicy.in/public_html/wp-content/plugins/td-composer/td-multi-purpose/styles/tds_icon/tds_icon1.php on line 9
Please make sure you have the latest version of the theme and plugins(11.2).
Sometimes, the issue can be from a plugin conflict also, that’s why, please deactivate ALL plugins except tagDiv ones, also if you are using child theme or cache plugin, deactivate them, clear all cache(also from your browser) and try again.
If this problem is not solved after that, then we need to take a look and see what happened there.
– admin url and credentials
– cPanel url and credentials
Our team will take a look!
