Hi!
Im working on this post:
https://veochubut.com/los-hermanos-barrientos-fueron-demorados-por-romper-la-cuarentena-en-chubut/
I want to activate the coments but I cant… When I scroll down in the post dashboard and go to coments/allow comments and trackbacks y pingbacks I check the boxes but when I save the post the check box is empty again… For some reason is not saves.
In theme panel/post and custom post type/ I have “Enable post on comments”
I other post the commets works fine:
https://veochubut.com/maderna-confia-en-el-buen-criterio-de-provincia-para-flexibilizar-el-comercio/
What could be the problem?
Make sure that you do not have a plugin conflict, please deactivate ALL plugins except tagDiv plugins, also if you are using child theme or cache plugin, deactivate them, clear all cache and try again.
In order to be able to have comments in post, you need to make these settings -> https://i.imgur.com/83CnhKi.png -> https://forum.tagdiv.com/enabledisable-comments/
Also in your case you are using a pro demo and you need to edit the single post template from tagDiv Cloud Library using tagDiv Composer like this -> https://i.imgur.com/1kebAnv.png and add the single post comments where you want to have it -> https://i.imgur.com/i9pnmBJ.png
Let me know the results!
