Problem width Navigation menu mobile
Hi, I’m new here and i have a problem with Navigation menu mobile you can see a left http://www.android-dz.com/ar/ , Please see this picture for understand : http://www.android-dz.com/ar/wp-content/uploads/2017/02/nav.png
The mobile menu navigation remains open, Despite the fact that I reinstall the theme , you can too see this problem in smartphone or mobile version.
Please help me 🙂
(Sorry for my bad english).
It seems that you have deeply customized the theme and there is no quick solution for this. There are custom settings set on some of the elements of the theme, and custom classes – https://www.screencast.com/t/ZYTUfI1Ctnv You must go over and check these customizations, where you have made them (theme panel or in the theme files) Or if you did not make those changes maybe a plugin could be the cause, so please try to disable all the plugins except Visual composer and the mobile theme, clear cache, purge cdn files and see if the problem is still there. A new theme install should fix this also, just delete the theme and install it again only using the required plugins that come bundled with the theme – https://forum.tagdiv.com/install-via-ftp/
