Problem with ads
I’m looking at the theme panel and attempting to make sense of the ad system. I have response ads setup with adsense and I’ve pasted the code within the header ads section. When I paste this it does nothing on the page. So I pasted the same within custom ad 1 and still nothing comes up.
When I goto the homepage I see its using AD BOX so I select the appropriate area, and still nothing. What am I missing to make this work?
Hi jtoney,
Yes, our theme it is using ad box and you can chose the source of code to be from the theme panel or you can set the code directly in the ad box.
Now, if it is a new ad account it can take a few days until this is approved, also you need to make sure that the ad account it is on that domain. Also, do you see any errors in console?
