Problem with bullets and numbering & header background
First of all, I love your theme it’s been fantastic.
But, I need some little help here
#1. Bullets and numbering
I’d like to make the second row onward to start exactly the same with the first row
Tried to dig more on CSS (probably it’s about list-style-position), but I failed as I know next to little on CSS.
here’s how it looks like on my post
http://www.screencast.com/t/7bOdWtnlnT
#2. Header Background
I wandered in this forum, found your link to a post how to tackle this thing. But, the link is broken. So I think I should ask you guys again.
And please do tell me the pixel size for the image best fit the area
Here the area I want to give background to:
http://www.screencast.com/t/hcm1Ah6c
That’s all guys. Thanks for the hard work
1. Try this css in theme panel > custom code > custom css: http://screencast.com/t/R8bZO3DKmcu
.td-post-content ul{
list-style-position: outside;
2. You can change the background color for the header from theme panel > theme colors: http://screencast.com/t/Dp3b7MS00tI5
The logo size depends by the header style used. With some header styles the logo it’s full width and with others have a limited size because it’s placed near the header ad. You can find more details about this in our documentation: https://forum.tagdiv.com/newsmag-logo-favicon/
If this is not what you mean please provide more details about this.
Problem #1 is solved
Problem #2: I need to put an image as a background to the area I mentioned before. Is it possible to do? theme panel wont let me do it (far as I knew)
Thanks Andrei L. for your fast response
Hello Syambarkah,
Unfortunately, there is no option for it in Theme panel, but you should try the code below to achieve what you want. Place the code in your Theme panel->Custom Css area alike this:
http://screencast.com/t/jRq4GQnNHb
If you want to have a full image in your header container, it is necessary to choose a correct size of image otherwise, you will have a free space in your header. The size of the container is 1021*130 px.
.td-header-header {
background-image: url("http://www.gettyimages.ca/gi-resources/images/Homepage/Hero/UK/CMS_Creative_164657191_Kingfisher.jpg");
background-repeat: no-repeat;
Here, you should see the result: http://screencast.com/t/4C8rrxjj
Thanks a lot Catalin, it is such a big help.
Thanks a lot
Regards,
Argya
Hello Syambarkah,
Glad that I could helped!
Thank you for the message!
