A couple of weeks ago, I started having an issue with the display of posts in the categories menu of the site fiestascostumbristas.cl.
For example, the post https://www.fiestascostumbristas.cl/2024/11/04/fiesta-del-agro-ancud-2024/ is in the “Los Lagos” category. It appears on the homepage but not in the corresponding menu: https://www.fiestascostumbristas.cl/region-de-los-lagos/
The same happens in the ‘Los Rios’ category, where it only displays 1 post, even though the category has 6
The same happens with all the latest posts. I have reviewed the theme settings and the cache, and Rank Math.
Do you have any idea what the issue could be?
Edit the category page with the tagdiv Composer, click on those blocks, and make sure there is no offset: https://forum.tagdiv.com/offset-feature/
Now the problem is worse: I entered a category with TAGDIV Composer to create a new module and see if this way it would correctly display the posts from that category, but now all the category pages have these same posts:
https://www.fiestascostumbristas.cl/region-de-nuble/
and etc. all display the same information, even though each of them should show different information.
Please, if you could pay attention to this, as the entire structure I had built for the site is not working.
