Problem with configuration of newspaper theme mobile
Hello
I need to remove the mobile template in newspaper x theme.
If you have the mobile theme enable, it will over right the mobile page and responsive version. If don’t want to use the mobile theme plugin just disables it or use it only for AMP => https://www.screencast.com/t/rsVMDvFTstah .
About mobile page template if you made a page template and after that, you delete the mobile page without unassigned it from the page still be linked. To remove the linked mobile page you need to create the new one then select the new mobile page after that you can delete the mobile page.
This is a video about Responsive Newspaper Theme, AMP & Mobile Theme, Mobile Pages & Templates https://www.youtube.com/watch?v=SpGkOnJeNZY
Hope this helps you!
So does that mean you can’t have AMP & Mobile Plugin installed and active if you want to use the “create mobile template”? If not do you Disable AMP and Disable or OFF Enable/Disable Mobile Theme for the, let’s say, Homepage Page? I was working on just making a mobile template page for homepage, but everything else AMP and Mobile original.
If I understood correctly, you made a mobile page for the homepage, but you want to use AMP and Mobile Theme plugins for the other posts/pages, for this you can disable the mobile theme plugin for the homepage from the Gutenberg editor using the following option => https://www.screencast.com/t/sEqNOLaOC
