Problem with Custom taxonomies
Hi, i’ve a custom post type “eventi” with a custom taxonomy “categoria-eventi”;
Whatever is the setup in this section, nothing change on the frontend: why?
Can i use a category template into a custom taxonomy (i’d like to obtain this)?
Thank you in advance
Hi vitaincamper, the custom post type is a little limited for the moment, you can achieve only what we have in this guide -> https://forum.tagdiv.com/custom-post-type-support/ also after the latest changes and modifications the custom taxonomy file that is use for theme panel settings is by default this one wp-content/plugins/td-standard-pack/Newspaper/archive.php and the theme panel settings are no longer apply. Now will be apply the settings that are made on archive page 0-> https://i.imgur.com/1o9FZxV.png
Thank you for your understanding and sorry for the inconvenience!
When wil this problem be solved?
Hello @Breinblik!
We don’t know exactly the date and time or if this will be considered as a new feature in the next updates, but we will try our best to bring you more best solutions in the future.
We are sorry for this inconvenience!
