Problem with Header Help ME!!
Hi everyone, I have a problem with Header, the menu overlaps with the header. also when I work in the Beckend of the Site some things I can’t see what it will really be like when the site is online. Thanks for your help
Hello !
Please make sure you clear your cache first. For cache we recommend using WP Super Cache: https://forum.tagdiv.com/cache-plugin-install-and-configure/
Also provide a link to your website in order to see what the menu issue is.
Hi Vlad, Thanks for the reply. I’ll briefly explain the problem. my site is not yet online, I’m working in Backand, when I go to see the page the menu overlaps with the topmenu. I’ll leave you the bypass link below. Thank you
https://www.vadoanapoli.it/?cmp_bypass=1234
Hi Vlad I believe there is a bug. I tried to create a header from a blank page. when I divide the row into 2 and on the left column I insert a logo, the column disappears and I can no longer insert anything. This also happens in the precompiled newspaper headers. I await your reply thanks
Hi Vlad I noticed that the keys to share articles on social networks have become transparent. could you check this too? I can’t understand what’s going on, everything was perfect. thank you
  • This reply was modified 6 years by gaevega.
The menu seems to be working fine on your website.
Also please note our working our for the followin day:
hello Vlad thank you, I tried your method, and now it has improved but I still can’t see the logo. I discovered that the plugin that is causing problems is header and footer, does this mean that I can’t use this plugin? but how can I send you screenshots of the screens to make you understand what is happening? Thanks again
I saw that the problem is the CookieBot code, if I remove it it also works with the Header and Footer plugin. But the problem remains of not seeing the logo.
I think I solved the problem with the Cookiebot code, but I can’t see the logo and advertising in the header from the backend
Hello !
In order to send a screenshot you will have to paste the link in here: https://www.screencast.com/t/wKc7QPWkwp
Also please provide a link to your frontend website so we can see the issue.
Hi Vlad I discovered the problem on the head when I insert the Divs of the advertisements. I don’t know if I’m wrong, but I insert a div for each device.
I insert the div for pc first, and everything is fine, then when I insert the div for display on smartphone the logo disappears.
Hello !
Where exactly are you getting the div, Also for ads please note that we have options to insert the ads in Theme panel by going into Theme Panel – Ads.
The path is theme panel / ADS / header ads and then I insert this code:
<div class=”td-visible-desktop”>
<iframe src=”https://rcm-eu.amazon-adsystem.com/e/cm?o=29&p=13&l=ez&f=ifr&linkID=d83d84821bae64d5a622a1f9320193c2&t=vegalabstore-21&tracking_id=vegalabstore-21&#8243; width=”468″ height=”60″ scrolling=”no” border=”0″ marginwidth=”0″ style=”border:none;” frameborder=”0″></iframe>
</div>
<div class=”td-visible-phone”>
<iframe src=”https://rcm-eu.amazon-adsystem.com/e/cm?o=29&p=42&l=ez&f=ifr&linkID=631c00c90e336ae01d48703e31bd98cd&t=vegalabstore-21&tracking_id=vegalabstore-21&#8243; width=”234″ height=”60″ scrolling=”no” border=”0″ marginwidth=”0″ style=”border:none;” frameborder=”0″></iframe>
</div>
at the moment the code is present on my site but if you see from the mobile phone no ads are displayed in the header
Hello !
If you’re using the Mobile Theme plugin you have to add the code in here too: https://www.screencast.com/t/JwxxvFNU
I don’t use the mobile theme
Hello !
– admin url and credentials
– cPanel url and credentials
Our team will take a look !
