Problem with header styles
If I assume I understand the Section of “Header Style” well, then I suppose that Style 6 and Style 7 are Similar in everything except colors
header styles
But when I applied them, they appeared like this
Style 7
Style 6
do you see the difference? style 7 looks like it has empty spaces, and active category, hover style in the main menu are not the same
The question now is how can i remove this empty spaces, make the action category and hover style in the main menu in “style 7” looks like Their equivalents in “Style 7”
Summary: how can i make the main menu in “Style 7” looks exactly like the main menu in “style 6” ?
links of pictures:
Header Style: http://imgur.com/ahFDtJb
Style 7: http://imgur.com/XTICSrh
Style 6: http://imgur.com/Qhon6Jl
sorry for my mistakes in writing.. rewrite my question again:
The question now is how can i remove this empty spaces, make the *active* category and hover style in the main menu in “style 7” looks like Their equivalents in * “Style 6” *
another question: how can i change blocks color?
I don’t fully understand why you would not simply use Header style 6 if that is the one you like, and why you want to modify Header style 7. Maybe you can explain better so I may give you a solution.
If you mean the block title color you can do it in the block settings
– https://www.screencast.com/t/MGUDuDud
More information about the available block settings and options here
– https://forum.tagdiv.com/block-settings-tutorial/
