Problem with images in posts
When I edit my post I always get a message for all images: “this block contains unexpected or invalid content” and “attempt block recovery”.
How do I fix that?
First, make sure that all theme settings are set like in our guide ->
The problem can be from Gutenberg editor, please follow this article to resolve the issue https://wordpress.com/support/block-error-unexpected-or-invalid-content/
Let me about your results!
I still haven’t solved the problem.
Every time I check the LightBox and when I try to correct the post again I get a message “this block contains unexpected or invalid content”.
For images where LightBox is not marked, I do not get this message.
I have one more problem.
I set the modal image enable in theme panel -> http://prntscr.com/q5fpll
But that doesn’t work with images in posts where LightBox are not marked?
I use Gutenberg editor.
The issue can be from a plugin conflict, that’s why, please deactivate ALL plugins except tagDiv ones, also if you are using a child theme or cache plugin, deactivate them, clear all cache and try again.
Please make a test only with tagDiv plugins, and see if the problem persists.
If after the problem is not solved, please make a full backup and contact us at contact@tagdiv.com, provide wp-admin and credentials, also a link to this topic in order to identify you.
