Dear all,
My website https://cafaggiincucina.com/ is facing problems with the Instagram widgets. I do not know because it does not work. Please see the imagens bellow.
https://www.screencast.com/t/jKp0Cu2T
Beyond that today I opened my page at my mobile and was crashed with some codes. How can I fix that?
See the images.
https://www.screencast.com/t/9gDtsPBoZ
Many thanks.
Hello !
Hello !
Please make sure to connect your instagram in Theme panel – Social Sharing as you can see in our guide here: https://forum.tagdiv.com/instagram-widget/
As for the shortcode please make sure you have all the required plugins active.
I solved now the problem with Instagram. Thanks.
But now i really need to correct the problem with mobile. Can you help me?
Regards.
See the images.
