We installed the mobile theme but now we have some problems:
1.- The menu doesnt show well. Sometimes the logo appers with a bad dimensions and the colors that we’ve defined for it are not load… other times the menu appera on the left side over the logo and no works.
Test on an iphone
We see the same page on the desktop (adding “/amp”) and appears ok
How could we fix this????
2.- The pages on the footer doesnt apperas also
Could you help us to solve this?????
We test
Hello !
You can use this css code: .td-main-menu-logo img {
position: fixed
.td-search-icon{
position:fixed;
The code must be inserted in here: https://www.screencast.com/t/s61BcemS2eW
Sorry but no works.
This is how we see the mobile theme on an iphone: https://imgur.com/T4rxNtU
Also we need to know why we could see the auto google adsense for amp.
We’ve activated it on the google adsense and this is how we config on the theme:
https://imgur.com/wmjiI2K (is ok the amp analytics code????)
How we could solve all this bugs??? Thanks.
Hello !
Please make sure that you have inserted your code correctly. As you can see here the code works: https://www.screencast.com/t/PecbdX5Il
The codes seem to be correctly placed.
That is the problem.
On the desktop explorer all display ok:
But on a real iphone NO:
WHy????? (i tested on safari and also on chrome and firefox iphone but all looks the same errors)
Ok,
Another thing…
Why google ads amp works on desktop iphone version but not in real iphone????
Also we have too pages on the footer but when we click on it nothing appers on the page….
Hello !
The pages don’t render because you are using The Mobile theme, was specially designed for optimization on mobile devices. Unfortunately on mobile theme you cannot do much changes of design. If you want to have the same design as on desktop mode you can achieve that by simply disabling the mobile theme.
You will have to recreate your pages into the Mobile editor or completely disable the mobile theme. The mobile editor will not render shortcodes !
In order to enter on a website as amp you will have to go through google search and from there access your website.
Ok Thanks,
But.. what about the google adsense on the mobile version?? Eveythinhg seems like is ok but we cant see ads on real smartphones?? (but if you test it as amp page on a desktop computer you can see the ads)
WHat is the problem???
Hello !
We have tested your website and it appears that you have ads on amp: https://www.screencast.com/t/jUFReoVE5s ; Please clear your cache and mobile theme ADS must be added here: https://www.screencast.com/t/e57nbQlM6L
Ok thanks.
We are going to use another amp solution.
