Problem with mobile theme
Sometimes it works, sometimes it uploads features that i’ve set up in the past and everything seems to be different from the latest update to the website that i’ve made. This morning i’ve tried to disactivate all the plugin, then clear the cache and then reset all the cnd file. For a while it seems to has worked, but now we are in the same situation of this morning. The mobile theme doesn’t work, even ifni disactivate the related plugin when i’ve try to visit my website from mobile it shows to me the mobile theme (but obviously not in the way that i want).
The mobile theme is very sensitive to caching. Please only use wp super cache and these settings: https://forum.tagdiv.com/cache-plugin-install-and-configure/
Also please contact your host and have them disable any hosting side cache.
Wp super cache also has a flaw in it;s code that must be adjusted as shown here:
https://github.com/Automattic/wp-super-cache/pull/185/files
Edit wp-cache-phase1.php and add the green code from the right column as it shows in the provided link.
I have the same problem. I am using the WP Super Cache + Lightspeed Cache plugin.
The Lightspeed plugin is required by the hosting company. I am using shared hosting on a lightspeed server, so with the Lightspeed plugin, the site is nearly twice faster 🙂
Any idea how to make them work together?
Sorry but we have not tested Lightspeed cache so I cannot offer any solution in this regard.
