Hello! I have a problem, if I turn on the plugin TagDiv mobile theme, then there is an error: “The mobile theme couldn’t be set. Please check if you already have another mobile theme plugin active and disable it (i haven’t). If you use a cache plugin clear it before checking the results” If I turn it off, then I can’t edit the mobile version. Please advise what to do?
@Daria The mobile theme will not work if the mobile theme plugin is not active. If it is active a different and simpler version of the website will be displayed. You can find out more about how the mobile theme plugin works here
– https://forum.tagdiv.com/the-mobile-theme/
This plugin is not required, you can choose not to activate it.
@baztiano After the latest theme update there seems to be an issue with the mobile theme plugin. We are currently working to solve the problem as soon as possible. Please deactivate the mobile theme plugin for the moment, sorry for the inconvenience.
