I have tried to reconfigure everything since your latest update related to AMP and mobile theme…
But now it’s quiet a mess…
I have several problems :
1- on the mobile version of http://www.byothe.fr, the top menu doesn’t work
2- the template doesn’t look like what you say… I don’t have the top grid
3- is it possible to customize the mobile theme… it really lacks of content…
Welle I am bit lost and the mobile version of my blog is really bad right now.
Hi byothe,
First of all, ensure that you are using the latest version of the theme NP 9.6.1. Here, it was made some improvements on AMP. That new update allows you to use the AMP with or without the Mobile theme. If you will use the AMP+Mobile Theme, the layout will look like this -> https://demo.tagdiv.com/newspaper_local_news/td-post-the-hottest-wearable-tech-and-smart-gadgets-of-2016/ Also, you have access to the Comments section. Regarding customization, notice that the Mobile Theme has a default layout and do not have any such an option that allows you to make some changes from the Theme panel, sorry! For more information about Mobile Theme layout and functionality, please check the following documentation from here -> https://forum.tagdiv.com/the-mobile-theme/
Hi Catalin,
but why your example (https://demo.tagdiv.com/newspaper_local_news/td-post-the-hottest-wearable-tech-and-smart-gadgets-of-2016)
does not pass https://validator.ampproject.org/ test?
Any of my pages could not pass this test also regardless which option is active: Mobile, Mobile+AMP or AMP.
Please, comment.
_Update_:
Now I found out that it was again “?amp” for AMP links? Which is not so before theme update when the url was the same for AMP and not AMP pages? Is it right and why so?
Denis Ugryumov.
That demo doesn’t have the AMP plugin active, it can be checked out on mobile as it has the mobile theme active. The AMP variant will look exactly the same.
Now after the latest update, to test AMP you can add to the URL this /?amp we have updated the documentation – https://tagdiv.com/amp-newspaper-theme/
There is an issue with the AMP comments currently, meaning that the fields of the comments don’t have a description or placeholder – http://prntscr.com/n2zr14
For this issue there is a quick fix in this topic – https://forum.tagdiv.com/topic/amp-and-mobile-theme/
I could take a look if there are problems when using our mobile theme and AMP. Please post a link to the website so I can test with the validator.
