Problem with mobile themes/view.
Hello. I have a problem with newspaper. The site doesn’t look alike on view on pc when editing homepage. It looks like it is loading from site defaults, from newspaper theme and the tagdiv doesn’t change anything on mobile. I don’t use JetPack, so this isn’t a problem.
Plugins I use:
– All in one seo
– AMP
– Classic editor
– Elementor
– Essential addons for elementor
– EWWW Image optimizer
– Copy and delete posts
– max mega menu
– nitropack
– premium addons for elementor
– royal elementor addons
– simple local avatars
– sitekit google
– snippet shortcodes
– tagdiv cloud library
– tagdiv composer
– tagdiv mobile theme
– tagdiv newsletter
– tagdiv opt-in builder
– tagdiv shop
– tagdiv social counter
– tagdiv standard pack
– wp statistics
– translatepress
– wpcode lite
– wpdatatables
I tried to on/off NitroPack, but still this didn’t worked.
URL of the site: https://superiongg.pl
You have the mobile theme plugin activated; please disable it.
Using our theme you can choose from 3 mobile versions
-> mobile responsive => https://www.screencast.com/t/oJ2ShOp47
-> mobile theme plugin => https://forum.tagdiv.com/the-mobile-theme/
-> mobile page => https://tagdiv.com/newspaper-10-3-7-update-brings-customizable-and-fast-mobile-pages/
If you created the mobile pages with tagDiv Composer, then when you install the Mobile Theme plugin, your pages will be overwritten by the plugin (the mobile theme comes with its templates for page, post, category, etc so your current templates from the desktop theme will get converted to the mobile theme layout, the page content is made without builders in mobile editor => https://www.screencast.com/t/xbgZG8kH also, the options that are provided to edit the mobile theme version are limited (this keeps the things simple)).
This is a video about Responsive Newspaper Theme, AMP & Mobile Theme, Mobile Pages & Templates -> https://www.youtube.com/watch?v=SpGkOnJeNZY
So, the mobile responsive is what you see then that you select the viewport on phone => https://www.screencast.com/t/matV17hH, so some settings may apply for each viewport(where is the border blue), and others are not(where the border is black).
The mobile page has the mobile templates from Cloud Library => https://www.screencast.com/t/YCcZ8rL8
Mobile responsive version of the theme and the mobile page editor can be edit with tagDiv Composer, the mobile theme plugin not.
For example, you can have the mobile theme plugin activate and use the mobile page/mobile responsive version for the homepage/pages, but for the categories pages/404 page you can’t use the mobile page/mobile responsive version if you have the mobile theme plugin activate.
So, if you want to design the pages with tagDiv Composer, you can use the mobile page or mobile responsive version.
Problem solved, thanks.
