Problem with modules
Ive got a problem.
On my test website by using cloud templates I add cali standard module and after that in module option I choose the thinh I created in cloud templates.
The problem is that the module is working corectly but it not shoes up any post – evan if I tries to chose diffrent post categories.
The webiste is available here: https://5zywiolow.com/moszna/
Please help 🙂
Please check if you have set here a post type, please delete it or replace it -> https://i.imgur.com/pZ3ehsc.png
Hello, thanks it works.
Ive got another problem.
On the same page
Im trying to use category simblings to be able to filter articles however im not sure if does it work that way.
Second thing is that I do not know where I can edit single articles – I would like to add there some description prices. Can you help me with that?
Also I would like to add bookmarks overt there but I have no idea how to do it .
Ill summary everything with the links, it will be easier for you to anwser.
1. Where can I filled that postiotion I marked on red
View post on imgur.com
2. How Can I add bookmarks or shopping card where customer can choose attraction he is intrested in and send me via e-mail request which is available.
3. Where can I choose which category will shown up it this sibiling category
1. I recommend creating your module because those are made in code. You can check this guide https://forum.tagdiv.com/modules-builder-newspaper-theme/ and this topic about the module made in code https://forum.tagdiv.com/topic/modify-module-file/
2. You can check those guides for bookmark https://forum.tagdiv.com/bookmark-save-for-later/ -> https://forum.tagdiv.com/woocommerce-happy-add-favorites/
3. Are you on a category or taxonomy? In the next update will be added more options to include, exclude https://i.imgur.com/b2c0U9x.png
