PROBLEM WITH MOVILE THEME
Hi. please, if you can help me with the mobile design of the template because it does not look like the design of the web.
I can not see the right sidebar, nor the post slide, the background in one part looks white when the bottom of the web is black.
PLEASE HELP!
THE WEB IS CHIPTECNO.COM
I have checked your website and I saw that you are using the Mobile Theme plugin which has a different layout than the desktop version. Please check the documentation from here -> https://forum.tagdiv.com/the-mobile-theme/ Did you have read this document before installing that plugin?
