Problem with my images
Hi, i have a problem with my images. This morning I upgraded WordPress to version 4.5 and now i can’t see pictures in the page. What is the problem?
Thank you very much for any information .
That happens because you’re using latest version of WordPress which generate a jQuery conflict with V 2.3.5 or older of Newsmag. We updated the theme and included the latest version of Visual Composer, V 4.11.2, which is testes and works fine with WordPress. Also we fixed the jQuery conflict so try to update the theme and the VC plugin following our documentation: https://forum.tagdiv.com/newsmag-how-to-update-the-theme/ – https://forum.tagdiv.com/newsmag-how-to-update-visual-composer-plugin/ clear all caches and test again.
I have the same problem on http://www.lifestar.it, could you help me?
I upgraded wp, theme and vc but no solution …
thank you
-Same problem, I followed everything as per the https://forum.tagdiv.com/newsmag-how-to-update-visual-composer-plugin/
-Cleared catch.
Still the issue exists.
http://www.kabir.org Check this!
same here. @devkabir your website kabir.org is displaying images. Please help us too.
Hi, I have created a new thread with my solution
https://forum.tagdiv.com/topic/solution-for-fixing-image-problem/
@ghostmi
I’ve checked your site and noticed that you’re using child theme. Try to deactivate the child theme, also deactivate all plugin except Visual Composer, clear all caches and test again.
@yamuuser
make sure you’re using latest theme’s version available on themeforest, V 2.3.6 and also update Visual Composer plugin at V 2.3.6 https://forum.tagdiv.com/newsmag-how-to-update-the-theme/ – https://forum.tagdiv.com/newsmag-how-to-update-visual-composer-plugin/ clear all caches and test again.
