Problem With My NewsMag Theme
Today I installed News Mag Theme. Theme is nice and working fine but I have few problems. Please look at that and give me solution
Website Link – http://www.top10wala.in
1. Mega Menu not working in categories, even though I selected Mege Menu while saveing Menu.
2. Below Trending now check blocks and images – Why images don’t cover whole block? Do i have to use certain size while uploading image?
3. Arrow navigation not working, from trending now to any block.
4. Smart Sidebar not working. Not on Home page not on Posts.
For now these are the problems i am facing.
2 More issues.
1. Search is not working
2. Smart list is not working properly. Check this link, i used smart list style 1. http://top10wala.in/20-interesting-facts-about-india-indians/
No Reply? I was hoping for a better support for tagdiv customers who already have purchased the theme. 🙂
1-3-5 Navigation, mega menu and search
have checked your site and noticed this scripts error in your console: http://screencast.com/t/izsj9JiIHtO8
This could be caused by a plugins as I have tested this using the latest theme version and haven’t had any issue with the pagination so please make sure you deactivate all plugins then empty cache and/or purge files if you use any cdn hosting service then check again.
2. Please try to regenerate your thumbnails: https://forum.tagdiv.com/how-to-fix-strange-thumbnails/
4. Please make sure if you enabled smartsidebar from Theme Panel: http://screencast.com/t/cINIP3dq
This issue can be also caused by JavaScript error.
6. For smart list issue please read here: https://forum.tagdiv.com/topic/smart-lists/
Hope this helps and please let me know if you still have this issue after doing all this.
1-3-5 Navgation, Megamenu and Search
So i have to disable all plugin and then start activating one by one to check which is causing problem?
2. What will this regenerate thumbnail plugin do? Will it change image size? Sure that won’t be a problem for my blog? I have installed it but waiting for your explanation
4. Smart Sidebar is enabled in my theme panel. How could I find what is creating problem?
6. According to smart list documentation, i did everything right. What else could be the problem?
1-3-5 Yes, and also make sure you empty cache and purge files if you use any CDN host services.
2. It will create several different thumbs for images which the themes needs and will be used on module/blocks/sliders.
4. This works based on js which I noticed that isn’t working at all on your homepage disable all plugins and make sure that you test this without any plugins active.
6. Please also test this without any plugin active and see if this still happens.
Hi, Thanks for your help.
I deactivated all plugin and checked my site. Everything was working fine. Then i started activating all plugin one by one and found out that W3 Total Cache plugin was creating problem.
So what should i do now? Is there any way to solve this issue? Or I have to use different caching plugin?
You can still use the W3 Total Cache plugin just makes sure you use it with just the page cache enabled and without the minification options or CDN: https://forum.tagdiv.com/how-to-make-the-site-faster/ the fifth step.
Thanks for support.
I did what you mentioned in your post and now every feature is working fine
