Problem with my Physical Memory Usage
hello i have problem with memory usage can you help me ty
hosting//////Problem with my Physical Memory Usage 1 GB / 1 GB (100%) I/O Usage 969 KB/s / 1
HTTP channel test wordpress
Installed demo i Default PRO – demo ID: default_pro | install type: full
Theme Mobile Newspaper mobile version
php.ini configuration
Server software i Apache
max_execution_time 300
max_input_vars 5000
SUHOSIN installed false
PHP extensions
mbstring available
GD library available
WordPress and plugins
WP version i 5.3.2
WP multisite enabled i No
WP Language i en_US
WP Memory Limit 256 MB/request
WP_DEBUG False
Caching plugin WP super cache – for best performance please check the plugin configuration guide here.
Hello !
– admin url and credentials
– cPanel url and credentials
Our team will take a look !
Thank you
I am also experiencing the same problem. The problem can be replicated when saving a Post, with only 1 character in the Post.
Hello !
Please send us a screenshot of your System Status Tab and make sure that all the requirements are met as you can see here: https://forum.tagdiv.com/requirements-for-newspaper/ ; You will have to first start looking for a plugin conflict. please deactivate ALL plugins except tagDiv ones, also if you are using child theme or cache plugin, deactivate them, clear all cache and try again.
Also you can try and remove and re-install the tagDiv Composer plugin and please send us a link to your website in order to take a look.
Let us know the results.
