Problem with MySQL after installing Newspaper 11
Hello, question. Is is posible that the theme caused a problem with my server? I installed Newspaper 11 and TagDiv Composer last night (my web was working on newspaper 9 and with the WP Bakery) and snce i made the new home page my website shows the “error establishing a connection to the database” every now and then, it works perfect for an hour and suddenly that, and so on. So is it something that could happen with the theme? maybe over saturation of the server for the instalation? of so what should i do? Thanks!
First please check the theme requirements -> https://forum.tagdiv.com/requirements-for-newspaper/ and please be sure that all requirements are set at least like in our guide.
After that please check the mysql version, it is recommended to use an updated version.
If all of those are set then remains the resource that are allocate to your website. You should have at least 2GB for ram and cpu.
Also, it is possible to have a plugin conflict (usually this is happen on the moment you enable the plugins that are in conflict).
Please also check this guide -> https://www.wpbeginner.com/wp-tutorials/how-to-fix-the-error-establishing-a-database-connection-in-wordpress/
