I have a problem making changes to the newspaper theme from the theme panel.
After making my desired changes, when I click on the save button, it just keeps on loading and loading, indefinitely. I attached a picture of what i mean
In most cases the issue is caused by one of the cases below:
Could be caused by insufficient resources
In this case the hosting provider should be able to increase them.
Or it could be a security setting, module or firewall, as in this case where the theme panel was not saving any settings
– https://forum.tagdiv.com/topic/cant-save-theme-options-2/
Also if you use Wordfence try to set it on learning more
– https://www.wordfence.com/help/firewall/learning-mode/
If you already checked or tried these, we could take a look. Send us an email at contact@tagdiv.com and provide admin login, also cPanel or FTP if possible. Please include a link to this topic in the email.
