I have a problem with page loading. For example, if I press on “load more” the icon disappears and does not load anything. If I enter the number of pages and press any number it does not load anything. Any suggestions for the problem?
Thanks in advance for your reply.
my site is: https://www.moviemag.it
1. disable TagDiv Composer
4. install TagDiv Composer
5. activate TagDiv Composer
Also, make sure your WordPress and plugins are up to date(specially Standard Pack installed and active if you use default templates).
Sometimes, the issue can be from a plugin conflict, that’s why, please deactivate ALL plugins except tagDiv ones, also if you are using a cache plugin, deactivate it, clear all cache(also from your browser) and try again.
We recommend using WP Super Cache plugin https://forum.tagdiv.com/cache-plugin-install-and-configure/
Let us know about your results!
