Problem with Open Graph
I have a problem with the Open Graph meta tag on the https://manchestercity.pl/ website.
I added it via the Yoast SEO plugin and although it is visible in the code, Facebook does not generate thumbnails for posts.
Increasing the image size does not help. I am afraid that this may also affect the omission of the page in Google News.
Please help
Check this guide: https://forum.tagdiv.com/facebook-share/
I hope that helps you!
This doesn’t tell me much, especially the strange server code…
Test
Do you use any security plugins or CDN?
RSFirewall! and Sucuri Security – Auditing, Malware Scanner and Hardening
I disabled both, but that doesn’t change the code…
It should interfere there somehow. Make a test and deactivate ALL plugins except tagDiv ones. Also, if you are using a cache plugin, deactivate it, clear all cache, and try again. Please get in touch with your host and ask about this issue.
