Hi, had this problem from the update, was hoping that there is something with the caching, but the problem is still here, so decided to try and get some help on the forums.
The problem is simple. When previewing a still not published post, the post format preview changes to tablet, and I am doing this form a desktop, just to be clear.
The post looks like this
Is there a solutions to this ?
Also, on the bottom of the page there is this info:
Warning: require(/home/smartpor/public_html/wp-content/plugins/td-composer/legacy/Newspaper): failed to open stream: Success in /home/smartpor/public_html/wp-includes/comment-template.php on line 1510
Warning: require(/home/smartpor/public_html/wp-content/plugins/td-composer/legacy/Newspaper): failed to open stream: No such device in /home/smartpor/public_html/wp-includes/comment-template.php on line 1510
Fatal error: require(): Failed opening required ‘/home/smartpor/public_html/wp-content/plugins/td-composer/legacy/Newspaper/’ (include_path=’.:/usr/local/php71/pear’) in /home/smartpor/public_html/wp-includes/comment-template.php on line 1510
The site is experiencing technical difficulties.
Please make sure that your problem is not caused by the cache plugin, please clear all cache and deactivate the cache plugin and try again.
Please make sure that you do not have a plugin conflict with untested plugins, please deactivate all non theme/tested plugins, also if you are using child theme, clear all cache and try again.
Hello @sthifer!
Let me know the results!
