Problem with setting theme at mobile + search bar problem
I’m having a trouble with setting mobile site. All the graphics are broken, also scheme of all the modules I’ve setted on site doesn’t work on mobile just as at full site version. There are only all the articles in one row, without graphics.
I have mobile + AMP turned on.
-> https://imgur.com/a/QfS0D4A
-> https://imgur.com/a/u6DPiGl
When I just turn on AMP it seems okay at my LG V30, but at Iphones and all the other phones I have to tick full site mobile version and then it shows properly.
-> https://imgur.com/a/CFWmuyC
-> https://imgur.com/a/6sVWSt3
-> https://imgur.com/a/NLmmp5B
Yesterday I also tried to translate search bar, but right after translating, this thing happened to me -> https://imgur.com/a/6tpODdo
Can you please help me find solution?
I just turned on thumbnails and it works.
But meanwhile I still have a problem with setting up mobile theme properly.
1. How can I change sections in mobile theme? I can’t do this in tagdiv editor. I would like have to similar layout to pc layout.
2. There are some words which hasn’t been translated.
3. Also my menu doesn’t work – there just an information “click here – to use the wp menu builder”.
Hello !
1. Hello !
The Mobile theme was specially designed for optimization on mobile devices. Unfortunately on mobile theme you cannot do much changes of design. If you want to have the same design as on desktop mode you can achieve that by simply disabling the mobile theme.
You will have to recreate your pages into the Mobile editor or completely disable the mobile theme.
2. What are those words ?
3. You will have to set your menu in Appearance – Menus – Menu Location: https://www.screencast.com/t/G4uB22EZ
The words are “Follow us”, “Contact”, “Name”.
What about this ? https://imgur.com/a/6tpODdo
How to change it so it appear as it should?
You can translate the words “Follow us”, “Contact”, “Name” from theme panel > translate -> https://i.imgur.com/2FkjfLI.png
Please check if this -> https://i.imgur.com/0vL3tES.png problem appear only on tagDiv Composer or it’s displaying on desktop too, I just make a test and I can not reproduce the error -> https://i.imgur.com/pU3Ixdq.png
That’s propably because You didn’t check my site….
It does appear at every computer.
Yes, I’ve checked your website -> https://i.imgur.com/cJU4RIa.png and the questions was if the problem appear only in tagDiv Composer -> https://imgur.com/a/6tpODdo or on frontend to -> https://i.imgur.com/x5plcl2.png if the problem persist on both ways, you can send us an email at contact@tagdiv.com and provide admin login, as well as cPanel. We will take a look. Include a link to this topic in the email.
