I did migrate my blog and I’ve got a problem with allsidebars.
Here is the test url :
Thank you for the support
I have tried to access your site url, but require user and password. Also please provide more details about your issue.
Oh sorry;
You can accès by using :
login : allforweb pass : allf0rweb
As you can see all the elément like the sidebar are missed up an can’t fix it..
I have checked your site and did not found any issues with the sidebar on homepage, post, category:
http://screencast.com/t/bPzBwrBQB
http://screencast.com/t/HMPE9pUuGOtX
http://screencast.com/t/6TY3J4kn3BK
Please empty cache if you use a cache plugin and also follow our documentation – https://forum.tagdiv.com/newsmag-documentation/
Let me know if you still have issues related to the theme.
Yes my mistake I did connect the wrong Database I was testing some solutions.
Now is my install on
Could you please check again ?
Thanks a lot
I have checked your site and seems that is missing a class there, so please update your theme to the latest version 1.6 following this guide and use FTP method: https://forum.tagdiv.com/how-to-update-theme/ Also update the plugins that come with the theme’s files from /plugins folder: https://forum.tagdiv.com/how-to-update-visual-composer-plugin-wpbakery/
Let me know if you still have issues with this after update.
Hello;
Thank you for your repply;
I did the update and nothing have change.
Do you use child theme?
If you do please switch to the main theme and check if you still have this issue. Also if you use CDN please purge your files.
I’m already on the main theme.
What is CDN ? I don’t use any cache plugin
Please give wp-access so we can have a closer look at this and your login credentials via email at contact@tagdiv.com
Please also include a link to this conversation or provide your issues details.
