Problem with single post template
I have a problem with Post template… I can’t choose a template for all post of my site and, Visual Composer is not visible in post edit mode…
The only thing I can change for a post is with sidebar on left or right, or no sidebar at all…
Please help as soon as possible as I expect to go live with my website today…
printscreen
I would like to use Visual Composer for design of my posts but the only thing I can change is this… (in red)
  • This reply was modified 10 years by Mantis.
The post settings are not found on the blog and post template settings. Those apply to posts that do not have any settings in particular. please edit the post and you will see the settings for it under the tiny mce editor in post edit.
Visual composer in our theme is only recommended on pages, not pots, but if you want to use it, you can activate it for posts from the visual composer settings.
Thanks for your response.
So, how can I set a template for all my existings posts, like in your demo site : http://demo.tagdiv.com/newspaper_sport/td-post-racing-geared-up-for-world-rx-of-france-in-europe/
In the sidebar’s demo (in the link below), you have “Latest news”, “must read” etc… How can I do that ?
If your posts do not have any specific post template set, you can set it from here globally: http://screencast.com/t/0pgVdpe7yO If your post has a specific post template set to it and it;s not set to “from panel” then the option will not work for that specific post as a setting from post edit overrides the theme panel. As for the sidebar blocks, you can set a sidebar to any post or catgory and add blocks to it the way you want them. Please read the documentation as everything you need to know is already written there:
https://forum.tagdiv.com/sidebars-tutorial/
https://forum.tagdiv.com/block-settings-guide/
Thanks a lot for your support.
