Problem with Smartlist and mobile
For some reason, my smartlist postings aren’t coming up correctly on mobile. I am using smartlist 2 where is doesn’t require the user to hit the next button to load a new item. Instead, a user can just scroll down the page and see all the numbers. This use to be te same if someone viewed it on their mobile device. For some reason, if someone views it on their mobile device, they have to hit the next button to see the next list number. On a desktop, it still works where someone can just scroll down the page, just not for mobile and it’s annoying. For some of my smart list, I have a long intro. So if someone on mobile views that posting, they have to keep scrolling halfway down the page and load the next item. Is this a bug or did something change? Does anyone know how I can have a single page smartlist 2 for mobile where a user can just scroll down the page?
Does anyone know what might cause this issue or how to get it back to where you can just view it on one page in mobile?
Please note that when using the mobile theme plugin, this comes with predefined templates for pages, posts etc. There is only one smart list template available, and that will be displayed regardless of what is set on desktop. If you want it to display the same, just disable the plugin. You can not have only parts of the website display with the mobile theme. The theme has full responsive design for every device and will display the same content like on desktop adapted for smaller screens.
More information about the mobile theme here – https://forum.tagdiv.com/the-mobile-theme/
OK, Thanks
