Problem with system status
I’m having many problems with the theme.
I have followed the guide but it doesn’t work.
Thank you
Does your host allow you to make those changes? Contact your host for assistance. As for the memory limit, just add this to wp-config.php (preferably above where it says “do not edit…” define(‘WP_MEMORY_LIMIT’, ‘64M’); (I don’t work here).
Indeed, insufficient resources can cause issues
https://forum.tagdiv.com/system-status-parameters-guide/
If you still have problems, please mention them and we will try to help you.
