Problem with tagdiv composer
Whenever I try to edit the start page of my site with tagdiv composer I get this error:
This site can’t be reached
The webpage at https://fontan.nu/wp-admin/post.php?post_id=1123&td_action=tdc&tdbTemplateType=page might be temporarily down or it may have moved permanently to a new web address.
ERR_HTTP2_PROTOCOL_ERROR
This happens both when I try to do it from the WordPress interface and if I go to the site and press the bar at the top.
What am I doing wrong?
Thank you inadvance
Best regards
Amanda at Lunds Fontänhus
First, I suggest setting the theme requirements https://forum.tagdiv.com/requirements-for-newspaper/, add this code too https://prnt.sc/MQRKxmjITK4V, in the htaccess file. You can add it at the bottom of the existing code. Then check if the composer works correctly.
Hello again!
I was too late getting this to my support for wordpress so when we finally looked at it, the link to the image was no longer valid. Also, we found that there are several files named htaccess and wondered which specific one you meant if you could specify.
Thank you in advance
Best wishes
The screenshot is referring to the last code from the guide:
In some cases, the mod_substitute module default configuration may cause a timeout error on TD Composer when loading large pages. To fix this you have to add the following lines in the .htaccess file located in your website main folder: – https://forum.tagdiv.com/requirements-for-newspaper/
How to Access and Edit the Default WordPress .htaccess File
