problem with TAGDIV COMPOSER
impossible to modify the contents of my home page with tagDiv Composer
Please provide some more details, some screenshots and a link to your homepage.
Similar problems:
-> https://forum.tagdiv.com/topic/the-message-is-errors-columms-elements/
-> https://forum.tagdiv.com/topic/not-able-to-edit-home-page-edit-with-td-composer/
more detail the large part of my site was done locally without problem for the modification. But when I hosted it on the server, we noticed that we can modify it on other pages except the home page.
example if we even modify the title of a block, by clicking on the save button, a single message appears at the right edge instead of two
only: << header successfully saved >>
but “successfully saved content” does not appear
site link: https://www.mines-rdc.cd/fr/
  • This reply was modified 6 years by nkayilu.
Also make a test and with a new page/template to see if for this is working.
Please make sure that you do not have a plugin conflict, please deactivate ALL plugins except tagDiv plugins, also if you are using child theme or cache plugin, deactivate them, clear all cache and try again.
Let me know the results!
