Hi all, I want to ask for your help because a few days ago an error appeared with tagdiv composer. Tagdiv composer is not loading and is generating the errors shown in the following image. I am using the newspaper 8 theme and the problem appeared after updating to the wordpress version 5.7.1
<br />gif h<br />
I would like to know if it can be fixed without having to update the newspaper theme and thanks for any help you can give me to solve it if possible. Thank you very much in advance.
First of all, please make sure you have a backup done and then you can update the theme and the TagDiv plugins also.
Please take a look for this advice before updating: https://forum.tagdiv.com/topic/action-required-please-read-how-to-update-to-the-newspaper-theme-v-10/
I recommend you to make a backup and update plugins and the theme via file transfer, so that you don’t face any error: https://forum.tagdiv.com/how-to-update-the-theme-2/
If you do not want to update the theme, then downgrade the WordPress version.
