Problem with Tagdiv Composer Please HELP !
ps: I’m not a developer…
my colleague who is developer installed for me WordPress on FTP server with OVH… then he installed the theme Newspaper8 but never works well !
i can’t use Tagdiv composer, this message appear in #red once i open a page with TD Composer: Errors Happened during tdcIframeData.init() -> bindViewsModelsWrappers()!
Also, when i publish a new post and i want to view it, i cant’:
Empty page open with this message:
Not Found
The requested URL /thenameofmypost/ was not found on this server.
I can’t work on the website and it is making me crazy! HELP ME PLEASE find a solution.
The developer told me that it needs some php codes and he doesn’t code with php… i don’t know what to do.
First of all I would suggest that the theme system status is checked
Those parameters are essential in the functionality of the theme and theme plugins. If needed ask your hosting provider to increase the allocated resources.
That error would appear if you were trying to edit a page which has not been built with the tagDiv composer or contains elements that were not added with it. Please try the composer on a new page.
If there is still a problem, try deactivating all plugins except theme plugins. Check if this has any effect on the issue.
If you use an older version of the Yoast SEO plugin, there was a setting that caused issues with the composer, deactivate it if that is the case
– https://www.screencast.com/t/n8Cc35EofLh
The other issue with the not found links could be caused by a chnage in the permalinks structure. I found some similar topics online
– https://premium.wpmudev.org/blog/fix-wordpress-404-errors-when-post-page-exists/
– https://www.kasareviews.com/fix-wordpress-page-not-found-error/
– https://stackoverflow.com/questions/13149418/the-requested-url-about-was-not-found-on-this-server
Let us know the results.
Hi Simon,
The problem is solved.
The issue with the not gound was indeed caused by permalinks… the first link you’ve put had the solution.
Concernning the other problems, my dev solved them..
I’ve also deleted all the pages then tried with TDC directly.. it worked.
Thank you
