Problem with tagDiv Opt-In Builder
Hi, i had website developed on local from flywheel. It had subscription via tagDiv Opt-In Builder. But after migrating to live it did something to tagDiv Opt-In Builder plugin. Instead components all i can see is CSS code. I have tried to reinstall plugin but after activation it shows this log. https://ibb.co/TbMjzkV
Hello @maixner!
Please make sure you have the latest update of the theme and the plugins too.
Please execute these steps:
1. disable TagDiv Composer
4. install TagDiv Composer
5. activate TagDiv Composer
Let me know the results!
Can’t delete plugin. It says that i have it installed on my main site. And i can’t delete my site.
Hello @maixner!
You need to update the plugins too: https://forum.tagdiv.com/newspaper-how-to-update-a-plugin/
Hi, i deleted composer on my test site, but it completely broken it. It shows now only css code https://ibb.co/Lvvg4tg
edit: After instalation of composer is site broken.
  • This reply was modified 4 years by Maixner.
Hello @maixner!
Yes. In the steps above I said to uninstall and then install the plugins. So, please install and activate the TagDiv Composer plugin and this issue will be solved. Check if other useful plugins are active in the Newspaper -> Plugins.
