Problem with tags in the article.
Hello.
After update to version 8.7.2 I have a proble with tags at the end of the article.
When I click on the tag I see the link name like http://www.sitenamee.ru/-/tagname/. But there is no such a page and browser gets 404 error.
How can I fix this ?
Hello middle_urals,
Sorry but please notice that we do not have any bad reports in this case until now, regarding on our latest updates. Please make sure that the theme update has been made correctly via FTP way, according to our documentation from here -> https://forum.tagdiv.com/install-via-ftp/ Remove all of the untested plugins, clear all the caches and check the results. Try to re-save your permalinks and check the results. I have tried to access your website but with fail -> https://www.screencast.com/t/9NJ7hmwX1z
Hello.
Thank you very much forthe reply/
The correct addres of the site is http://uralstalker.ru/
The example of the page with tags http://uralstalker.ru/2017/11/razgadka-zotovskoj-steny/
But the language of the article is russian, I don’t know if it will be easy to check it. The tags are near facebook like button at the end of the page.
When i press the tag, for example, I get such a link http://uralstalker.ru/-/kraevedenie/
Actually, this page does not exist.
The theme was updated via Evanto Market plugin, but I have been using old version 7.7.1 before.
BR, Evgeniy Markov
Hello middle_urals,
Sorry, but I cannot access your website and therefore, I cannot see the problem, unfortunately! Please notice that we do not have any bad reports in this case and we recommend to use the latest version of the theme installed via FTP way because this is the surest method in this case. Try to make a new install to another sub-domain for testing only with required plugins and check the results.
Finally, 3 weeks ago I found the solution. The reason was not in the Newspaper theme. WordPress rewrote some global settings after the update to the version 4.9.5. So I fixed them, and everything works.
