Reviewing the problem of someone else in the forum, I found the solution to a problem.
Site logo has black background #000000 (on the site for computers and solve it), I’m using the style header 5 (black header), but the color is not the same as it has the logo, reviewing the forum I found this code:
.td-header-wrap .td-header-menu-wrap-full, .td-header-wrap .td-header-menu-wrap, .td-header-wrap .td-header-top-menu-full, body .td-header-wrap .td-header-main-menu {
background-color: #000000!important;
And I worked alone in the post, but in HOME and all looks the same category. In post everything perfect but in all categories and not turned Header.
*In the footer of all categories HOME and the same thing happens(in mobile), the logo has black color, but the color of footer is not #000000
Are you maybe using the mobile theme plugin? https://forum.tagdiv.com/the-mobile-theme/ If you use this plugin then any custom code you add in the theme panel custom code section will not work. you have to add css here:
http://screencast.com/t/nfBW3yhc0Dvy Please read this guide for more details on the mobile theme: https://forum.tagdiv.com/the-mobile-theme/
