problem with the tagDiv Mobile Theme plugin
I have a problem with the tagDiv Mobile Theme plugin because it does not show the function images on mobile devices
You aren’t alone on that one. my website is doing exactly the same. everything works fine on the desktop but none of the blocks a add with TagDiv are working on my mobile. nightmare.
Hello !
The designs do not match because you are using the mobile theme. The Mobile theme was specially designed for optimization on mobile devices. Unfortunately on mobile theme you cannot do much changes of design. If you want to have the same design as on desktop mode you can achieve that by simply disabling the mobile theme.
You will have to recreate your pages into the Mobile editor.
